Tom-"Our Air intake housing is 2400 series aluminum. just like the cases in your C-145" Air intakes are not the sort of critical item we were discussing. And BTW, the engine sump case in a C145/O300 is not aluminum, it's magnesium, not that it means anything. And the aluminum cases used for air intakes (elbows) in the 145,... I'm sure is OK to powdercoat air intake induction parts. Hardly the type problem we've been discussing. Air intakes aren't stressed items, and they don't suffer from heat dissipation problems.
How many T-56 brackets have cracked that you haven't noticed? You'll never know until it lets go. By that time, of course the powdercoating has cracked as well. In a tubular engine mount, we'd sorta like to notice before it gets that far. (BTW, my opinion in this matter is the result of the local DAR who showed me a powdercoated engine mount. It had cracked and failed just subsequent to an annual inspection that had inspected that mount. He convinced me that powdercoating can hide cracks, and he pointed out that it was not an approved process for mounts. I don't think this DAR is foolproof, but it was pretty convincing.) He recommended lacquer on mounts and wheels.
As a matter of interest, there are some new technologies regarding powdercoating that may do away with the heating or "thermosetting" as they call it of the powders. Some new powders are being developed that are cured with UV and/or Infra-Red light that show promise in this area. This would make the process available to those aluminum parts that would be heat damaged.
Also, the Kitfox experimental airplane can be ordered with it's frame predominantly powdercoated....but....they caution you that it is not powdercoated in the corners and at the welds where the kit builder is instructed to paint those areas with ordinary aircraft paints (usually recommending Stits products.) I know you won't believe it, but I've got an opinion as to why.
George - Across from some, but hopefully not cross-ways with friends.
