Polish
Polish
it seems to be the consensus of this board
that Nuvite Polish is the best for aluminum planes
it comes in 3 grades
what is the best type to buy
and is the best way to use it?
i have no heavy corrosion on my plane
thanks
dave
thanks
dave
1951 170A 1468D SN 20051
AME #17747
Re: Polish
my plane is just dull
so maybe will go with the finest also
thanks
dave
thanks
dave
AME #17747
Re: Polish
It actually comes in a bunch of grades. I am a novice polisher but so far I have used mostly F7 to start(F9 on the really bad spots). I plan on using C next and then finishing up with S. It is a long process but worth it. The perfect polish website has a ton of good info on polishing.
-Mike
-Mike
- rhymes
Re: Polish
Mike's right: the perfectpolish.com website has lots of good information.
NuVite is the good stuff, and a Cyclo polisher will help you get the best results. No secrets really... just lots of time and desire!
As has been said before, though: the 170 is such a pretty plane, how could you not want to polish it!??!
B. Rhymes
1954 C170B
N2865C
B. Rhymes
1954 C170B
N2865C
Bruce & Kathy Rhymes
1954 Cessna 170B
N2865C
1954 Cessna 170B
N2865C
Re: Polish
Nuvite is great stuff. On 35D I started with 6 then 7. C, A, S. Now to keep polished I just use C and S. Rusty.
Re: Polish
First flight this spring. Two hours to buff it up.
http://i624.photobucket.com/albums/tt32 ... d6b2b2.jpg
Fayetteville, WV
1948 Cessna 170
1941 J-5 project
1948 Cessna 170
1941 J-5 project
Re: Polish
I guess there is another advantage to the ragwing 170......no wings to polish!! Beautiful plane Ralph!!
Re: Polish
How'd you bend that prop, Ralph? Overspeed while taxying?
Pretty 170! That Verde' color-scheme is even nice!
(How 'bout some panel & interior pics?)
- n3833v
Re: Polish
I always think polishing is great and looks good, but in the 60's when I drove truck, I found it so much better to have painted wheels to clean than to polish aluminium wheels. It is nice that mine is a 48 so no polishing of wings and only wash and clean the painted surfaces. Kudos to all that spend mega time polishing so I can enjoy.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
Re: Polish
my cyclo-polisher has the two rubber rotary 'pods'
to these a rubber cap is stretched over the pods that have velcro on the other side
then all the accessory polishing pads can quickly attached to the pod
what is the part number for this rubber cap with the velcro on it?
thanks
dave
thanks
dave
AME #17747
Re: Polish
hi ralph young
you say you use the finest polish
is this Nuvite 'S'
could you describe in detail how you buff your plane...
ie what kind of buffer and how you apply the polish etc.
thanks
dave
is this Nuvite 'S'
thanks
dave
AME #17747
Re: Polish
i masked off the 'N' numbers before I polished
i'd like to make a template out of a thin rigid plastic or other material
so i could simply place it over the N number and just tape the out'r edges
what would be a good material to use for this
my 'N' numbers are 13.5 x 20''
'iowa'
AME #17747
Re: Polish
i traced out the 'N' numbers today on tracing paper
plan to cut them back 3/8" so a single piece of masking tape
will secure them down for future polishing.
i'm still trying to figure out what would be the best
material to use
plexiglass is too brittle to cut
so am thinking about using a piece of vinyl
which would lay nicely and be durable enough to
withstand the polisher pads etc.
how did the rest of you do your planes?
dave
material to use
dave
AME #17747
