Blueldr's car
Re: Blueldr's car
That was an ugly one...
Magnetic anomaly detection using aircraft predates World War 2 where it was used to detect submarines. It was used back in the late 1930s by oil companies to search for minerals and oil.
MAD has been used by Navy in P-3 for decades.
Here's a prettier DC3 using it:
Re: Blueldr's car
On the Dizzy Three above, does it always fly with the gear down with those skis on it?
pdb
Re: Blueldr's car
Post by pdb »
blueldr wrote:On the Dizzy Three above, does it always fly with the gear down with those skis on it?
I don't know about all DC-3s but the ski rig for our local ones look like the gear is always down. But they can choose to use the skis or raise the skis to land on the wheels.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
johneeb
Re: Blueldr's car
Post by johneeb »
Pete, do you know the function of the airfoil at the rear of the main skis?
canav8
Re: Blueldr's car
Post by canav8 »
John, I believe the wing is used as an anti fowler so that snow does not fly up into the flaps. Wet snow will build quickly and and could damage the flaps on flap retraction. Doug
52' C-170B N2713D Ser #25255
Re: Blueldr's car
I have been under the impression that the wing on the rear of the skis was to hold the skis in a tail down attitude while in flight so that they cannot "Nose Dig" on a landing. On small airplanes, like my L-5 in Alaska, that was accomplished with the use of bungee cords and limiting cables.
canav8
Re: Blueldr's car
Post by canav8 »
blueldr wrote:I have been under the impression that the wing on the rear of the skis was to hold the skis in a tail down attitude while in flight so that they cannot "Nose Dig" on a landing. On small airplanes, like my L-5 in Alaska, that was accomplished with the use of bungee cords and limiting cables.
I thought that was what the cable was for in the front of the ski? What is that used for then? The Dizzy also has those cables.
pdb
Re: Blueldr's car
Post by pdb »
I think BL's explanation is closer to the mark.
These skis are hydraulic which means that they can be raised or lowered in flight to allow takeoffs on snow and landings on pavement and vis versa. In the raised position, there will be some slack in the cables and I believe that the horizontal surface stabilizes the ski in flight when in the raised position. The stabilizer may also allow the ski to maintain a more neutral attitude in cruise.
When lowered, the cables will tighten and allow for the correct angle for the ski to make contact with the snow. Smaller skis use bungees to raise the ski tips up a bit so that the tails contact the snow first. I am not sure how this is managed with these big skis.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
johneeb
Re: Blueldr's car
Post by johneeb »
Is there some type of wheel or roller in the aft end of the ski's to keep them from grinding while operating on pavement?
pdb
Re: Blueldr's car
Post by pdb »
johneeb wrote:Is there some type of wheel or roller in the aft end of the ski's to keep them from grinding while operating on pavement?
John.. There are none on this set though they are not uncommon. The photo is a bit deceiving because I don't think the skis are fully retracted in the photo. I believe they are only partially retracted so the ski is resting in the concrete. When fully retracted, the ski would clear the surfaces.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
johneeb
Re: Blueldr's car
Post by johneeb »
ok, that makes sense. This is all pretty unusual for us flatlanders.
