delete
bigrenna
delete
Post by bigrenna »
delete
mit
Re: Alaska Bushwheels and Cleveland Double Pucks
Post by mit »
And drum roll please you spent how much? :wink:
krines
Post by krines »
Can you explain exactly what you did. I was interested in the same setup. What STCs are used. Is that ABW yoke installed on a Scott 3200. What are the tires and manufactures. Those tires look like they will wear better than the 26 inch ABW and are probably alot less expensive. And the drum roll, how much was the conversion. Steve
bigrenna
delete
Post by bigrenna »
delete
bigrenna
delete
Post by bigrenna »
delete
