Home made pre oiler
twlareau
Home made pre oiler
Post by twlareau »
Her are some pictures of our engine pre-oiler. We used this prior to starting our newly overhauled engine.
krines
Re: Home made pre oiler
Post by krines »
What is the purpose of a pre oiler? Steve
krines wrote:What is the purpose of a pre oiler? Steve
It "pre-pressurizes" the engine oil system prior to initial start-up after rebuild/repair. That way, the first time it starts, the oil pump and galleries should already be filled with oil and all bearings, bushings, etc. should already have oil on them.
Many folks assemble using assembly grease (such as Lubriplate) to fill the oil pump (to prime it) and to give the grease-smeared bearings/bushings/gears lubrication until the oil pump gets oil to it all.
Personally, I always dip pistons with their rings into fresh engine oil before sliding the cylinder onto them as well.
krines
Post by krines »
How does one accomplish the task of pre oiling with this device? Steve
One way is to connect it up to the oil pressure port and pump the engine full, the object being to fill all the oil lines, galleys, lifters, etc., so that oil will start flowing with the start of cranking rather than waiting for everything to fill up by running the relatively dry engine. Oftentimes the engine will be pre oiled then rotated, by using the starter with the spark plugs removed, until oil pressure shows on the O.P. gage, thus cushioning the bearings and journals for the initial engine start.
twlareau
Post by twlareau »
We would be willing to lend the per-oiler to any club member. You would have to supply your own drill to drive the pump. It worked great! Thanks Lars.
MoonlightVFR
Post by MoonlightVFR »
LARS
Would you be willing to share a sketch drawing and parts list to allow others to build their own unit?
Your offer is so generous, but loaning tools has a raft of potential problems.
Regards
gradyb, '54 B N2890C
