Evening... I was thinking of making a fuselage support that is essentially pieces of plywood cut to the shape of the fuselage between the gear legs. If I cut it to match the couture between the gear legs, make it slightly wider than the box that supports the gear legs and pad it with carpeting - does anyone see an issue with doing so. If I used two bottle jacks on each side I'm thinking it will be very easy to level the plane as I work on a complete rig / trim check etc and work on gear legs / wheels and the like.
Thoughts ?
Kyle
Fuselage Support
- Kyle
Fuselage Support
Kyle Takakjian
Truro, MA
52 C-170B, N8087A
Truro, MA
52 C-170B, N8087A
Re: Fuselage Support
I don't see and issue with the support. However why would you go through this trouble for rigging?
I'm of course assuming your not talking about rigging the gear in which case having them both off the ground might have some benefit.
But if your leveling the aircraft for control rigging then leave the wheels on the ground. To level the aircraft laterally let air out of a tire.
- blueldr
Kyle,
I have an example of the device you are describing, I made it many years ago and have used it many times. I used a piece of cardboard to cut and fit it to the curve of the bottom of the fuselage between the gear legs. The curve was then transferred to a piece of 4 X 4 lumber and it was cut out with a band saw and lined with carpet. The airplane can be set upon it using either cribbing or a couple of sturdy saw horses or whatever. I've used it for years. Real handy device when working on the main gear.
I think it will fit just about any 100 series Cessna.
- johneeb
- Kyle
Thanks for the suggestions and pictures everyone. And Bruce the wheel method makes perfect sense although in addition to leveling for rigging, this year I’m pulling the wheels, wheel fairing mounting plates, etc. so having both wheels off at the same time without beating up the gear legs will be nice. John – nice rig – Aluminum or Stainless? Although the quickest and simplest may be Blueldr’s method. Either way, we are going to go through the 170 rigging document step by step and hopefully solve the left wing heavy issue. Last year we checked all basic rig specs and didn’t find anything seriously off – so it will require a more in depth look.
Kyle Takakjian
Truro, MA
52 C-170B, N8087A
Truro, MA
52 C-170B, N8087A
The 100ll Series Service Manual illustrates how to build a fuselage support.
- johneeb
Kyle,
The support is made of a scrap of 1/2x3" steel strap, bent in a bench vise, with 11/2" pipe caps used for jack sockets and painted gray.
