i am new to the forum and to 170s i just got a 1949 a and would like to know the tire pressure for the rear wheel
rags 9100A
tail wheel air pressure
Re: tail wheel air pressure
35lbs.
And welcome to the forum, the Association and 170 ownership.
- N2255D
Welcome to the forums and the wonderful world of 170 ownership.
Walt Weaver
Spencer Airport (NC35)
35 lbs?
I put 45 in mine before I put everything back together and it looks half flat.
Maybe I need a new gauge.
Oh yeah, Welcome to the forum!!
- lowNslow
You are supposed to put 35psi in BOTH halves, most forget to fill the bottom half.bagarre wrote:35 lbs?
As it turns out, my tire gauge IS bad. I checked it against another one and it was nearly 20 pounds off!
Filled the tire to 35 pounds and it works great.
