Metco Aire Hoerner Tips: Snake oil or enhancement
pdb
Post by pdb »
I like the looks of these but do they deliver the benefits promised?
http://www.metcoaire.com/products/vwd_justso.htm
http://www.metcoaire.com/products/product_cessna.shtml
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
Re: Metco Aire Hoerner Tips: Snake oil or enhancement
Pete,
I've not personally used these. But I am aware of the aerodynamics envolved which can lead to all of their claims in varying degrees. Based on similar tips and other aerodynamic tricks which do the same stuff I wouldn't be surprised if you see all these improvements. I also wouldn't be surprised you find some or all of their claims don't stack up. If I was to make a dollar bet I'd bet you find they do something to improve the performance of your plane. There has to be some reason Cessna switched to this style when they could have just make more simple symmetrical interchangeable tips which would have been cheaper to make or buy.
If you like them buy them and don't look back.
Bruce Fenstermacher wrote:...There has to be some reason Cessna switched to this style ....
When did Cessna switch to the Hoerner tips? (I believe they developed a totally different tip, as shown in Hoerners own sales literature.)
Your right George. I made this mistake before. Cessna developed a droop tip which uses different aerodynamic tricks to achieve the same thing as the Heorner design.
