Removal of wing struts, "V" struts
Removing the wings from my 1948 Cessna. I have all cables, wires, fuel lines disconnected and all fittings loose except the lower wing strut bolts which I can just feel through the two small access holes in the cabin floor. Any tricks or tips?
Fayetteville, WV
1948 Cessna 170
1941 J-5 project
1948 Cessna 170
1941 J-5 project
Re: Removal of wing struts, "V" struts
Be certain to support the struts and never allow them to fall before you get that bolt out, or they will tear the skin of the fuselage.
Thanks, we will have all hands on deck. I have some scaffolding I will set up under the wing with a mattress on top. Then I built a wing cradle to hold the wings, leading edge down in a carpet sling.
Fayetteville, WV
1948 Cessna 170
1941 J-5 project
1948 Cessna 170
1941 J-5 project
- daedaluscan
I have a B with a single strut, but replacing all bolts with punches or pins before the final removal makes the job easy..
We did it with three, one to hold wing tip, one to remove the srut, and on on the inner wing. Very straightforward.
Charlie
1956 170B C-GDRG #27019
Thank you for the tips. The wings came off in less than an hour. They are now sitting in a 2 x 4 cradle I threw together as the bolts were coming off. I am sure putting them back on will be more of an ordeal.
Fayetteville, WV
1948 Cessna 170
1941 J-5 project
1948 Cessna 170
1941 J-5 project
Fayetteville, WV
1948 Cessna 170
1941 J-5 project
1948 Cessna 170
1941 J-5 project
