Spark Plug part number
Posted: Mon Jun 17, 2013 2:07 pm
by BlakeinAlabama
What is the best plug to use in our engines? I am not at the hangar right now and I don't know what I have in it now. Can someone tell me which ones we use? Thx, Blake in Alabama
Re: Spark Plug part number
Posted: Mon Jun 17, 2013 3:40 pm
by spduffee
RHM40E, if you have the 3/4" version or REM40E for the 5/8". We both should n=have the 3/4". I just bought the Tempest URHM40E's and installed them.
Posted: Tue Jun 18, 2013 5:54 am
BlakeinAlabama wrote:What is the best plug to use in our engines? I am not at the hangar right now and I don't know what I have in it now. Can someone tell me which ones we use? Thx, Blake in Alabama
The most common are REM40E.
Posted: Tue Jun 18, 2013 6:35 pm
by spduffee
Uh-oh - did I just install the wrong ones? I referred to the Champion spark plug guide. If I keep the RHM is it going to cause me any heartache? I haven't fired up the engine, yet....
Posted: Tue Jun 18, 2013 6:53 pm
If your wiring harness fitted up to the plug...then you're good to go! (The difference is the size of the "nut" which screws onto the plug.)
Posted: Tue Jun 18, 2013 7:03 pm
by spduffee
Oh, thank goodness....Then I am ok. Thanks George.
Posted: Wed Jun 19, 2013 3:21 am
by blueldr
George,
Aren't you going to go into the numbers and the heat range on the plugs?
Posted: Wed Jun 19, 2013 4:54 am
Just because he asked... :roll:
The numbers indicate the heat-range...higher is hotter, lower is cooler. (The range is from 26 to 50)
The MX Library has a chart in the Engine section which includes the Champion brochure about this:
ChampionAerospaceCatalog.pdf
Posted: Thu Jun 20, 2013 3:44 am
by BlakeinAlabama
I looked at mine tonight and you were right, rem40e for me.
