Interior Air Vent gromments
rupertjl
Post by rupertjl »
I'm trying to replace the air vent grommets (p/n 0413235) found in the A model PM on page 74-75 figure 40. Cessna wants $170 a piece for them and I need two...I've done the local hw store search, I can't seem to find anything similar in size. I measure the old ones at a 2" ID and a 2 7/8" OD with a 2 1/2" channel diameter and 3/8" thickness. Anybody know a different source for these parts? I probably could use the old ones but after doing all the work to paint the interior metal, it would look like a cow sucker I think...
Thanks!
1950 170A: N9191A s/n 19366
Re: Interior Air Vent gromments
I'm in the exact spot so if we find them, maybe we can save money with a bulk order.
I'm sure there are a few more out there that need these.
bigrenna
delete
Post by bigrenna »
delete
rupertjl
Post by rupertjl »
Just called Air Repair, for anyone needing the p/n it is 0610074 and they are selling for $28.50 a piece.
learaviator
Post by learaviator »
Rubber grommets.com will send you a couple of samples if you call them and tell them you are building something that needs that size. They sent me 6 free samples, I used two and gave the rest away to members here.
"You can only tie the record for flying low"
1950 170A N9907A 180hp. STOL
