Gross weight (Floats)
minton
Post by minton »
Anyone have any ideas why the gross weight on floats is 100 lbs less?
Anyone working on an increase?
C170U2
Re: Gross weight (Floats)
Post by C170U2 »
Per the A model POH the max gross weight on floats is 1975, without floats is 1900.
C170U2 wrote:Per the A model POH the max gross weight on floats is 1975, without floats is 1900.
8O :?: :?: :?: 8O
Gross wt of the landplane is 2200.
Floats impact the balked-landing-climb requirements and add stress to the doorposts, firewall, and attachpoints. Reducing the Gross Wt. reduces those problems (among other things.)
C170U2
Post by C170U2 »
Ooops, I was looking at the "Utility" portion of the manual. Sorry for the misinformation...
minton
Post by minton »
8O :?: :?: :?: 8O
George,
That's what I'm getting (Balked landing) C-145/0-300. With 0-360 and 175 wings (2550 gwt) STOL kit/VG's, 80 Hartzell, mine definitely performs. Rumor has it that Del-Air was looking into a GWT increase for C-170's but I've been unable to confirm it through his old outfit or Wipare.
In researching structure issues I have not found the 170B to have many negatives that would hinder an increase. Station 90 would probably need a little work. Heck 2300 lbs would be great vs 2100 (Float) now.
Anyone interested in teaming to get a DER to look into it??
minton
Post by minton »
Stoots aviation sez a combination of larger engine and larger tail feathers such as the 170 "C". Anbody have pictures of such??
minton
Post by minton »
In combination with Wipline 2100's you get gwt of 2200lbs. ART/WingX STC for GWT of 2400lbs is a bust. He's blow'in smoke about getting it approved in the US. Been at it for years with no results. :D
kbbell
Post by kbbell »
Is the WingX approved for 2400 lbs in Canada?
minton
Post by minton »
[quote="kbbell"]Is the WingX approved for 2400 lbs in Canada?
According to WingX, Yes
CF-HEW
Post by CF-HEW »
I believe the 2106 lbs gross weight on floats is an Edo 2000 limitation due the the buoyancy (lack thereof) of the floats. Is it not 2200 lbs with larger floats?
Alex Gloutney
'53 B model s/n 25901
minton
Post by minton »
Wipline 2100A has STC for C-170 A/B 2200lb gross. (STC00804CH) the 2106 lb number shows up in the TCD sheet but doesn't mention the EDO float although it does in other areas so who knows??
