170B gear legs
170B gear legs
Hello
I am looking for gear legs newer style for my Cessna 170B, Serial 20615, 1952.
The installed gear legs are very soft.
has anyone a set in good condition for sale?
Kind regards
Paul Misteli
Birkengasse 7
4583 Aetigkofen
Switzerland
misteli.p@bluewin.ch
Kind regards
Paul Misteli
Birkengasse 7
4583 Aetigkofen
Switzerland
- Blue4
Re: 170B gear legs
Hello Paul,
I still have a set of nice lady legs for sale. You can view the older ad in the trademart forum.
-Scott
-Scott
Re: 170B gear legs
do you still have lady legs for sale ? thanks doug
- Joe Moilanen
Re: 170B gear legs
I'm looking for some too, any more out there???
360-430-0634
360-430-0634
Re: 170B gear legs
Paul Misteli wrote:Hello
Paul-
Are your gear legs still in good condition or have they failed in some way? The 170 gear by design is soft compared with 180/185 gear if that is what you are comparing them to. There are shops in the USA that can recondition your gear up to re-heat treating if you think they have been molested in the past.
If you are wanting to upgrade to stiffer gear, TIC170A owns an STC to convert the C-170 to C-180 gear. 180 gear are about 3" taller but much stiffer if that is what you are looking for. C-180 gear are probably easier to find as well. New 180 gear can still be purchased from Cessna but not cheap.
- blueldr
Re: 170B gear legs
If you're seriously thinking about installing C-180 gear legs, please be advised that there three different series of them. The first type, or originals, were so called "Straight" legs. The second series were tweaked at the upper end bend to move the axle center line forward about 3 3/4 inches when installed. These were the series I used when I installed the heavier IO-360 engine and CS prop. The third series was, I believe, slightly heavier and common with the C-185 aircraft. They will all bolt right in to the C-170 gear box. You might have to thin down the locking wedges to get them in.
- Joe Moilanen
Re: 170B gear legs
I believe Paul and I were talking about Lady Legs, late '53 and beyond.
360-430-0634
360-430-0634
- blueldr
Re: 170B gear legs
Agreed. But if you can't find a set of "Lady Legs" and may want to revert to C-180 legs------???
Re: 170B gear legs
We still don't know if there is anything wrong with his gear. He was just complaining about them being soft not defective. They are all soft, that's why I mentioned the 180 gear.
- Joe Moilanen
Re: 170B gear legs
I'm on the hunt for some "Lady Legs" as Paul is, they are a good "in-between" the soft originals and the 180 legs.
