New Fuel Valve question
piclr60
Post by piclr60 »
I have investigated the forums on all the info on the fuel valve. I understand how it works and the pit falls on the cam riding up or down to allow the balls to fall in the valve shutting fuel off. I may have missed something but what would cause the fuel valve to not shut off fuel at all? Fuel still flows in the both off positions. I thought i read somewhere on the forum the cause of that but can not come up with where I read that. I also scanned the fuel valve article George wrote in the 2011 1st quarter. Any help please?
Brad
johneeb
Re: New Fuel Valve question
Post by johneeb »
Brad, have you taken the valve apart and determined if the balls are missing?
If the valve is assembled incorrectly ( as the IPC illustrates with the O-ring improperly placed) the fuel will never shut off completely.
The article I wrote which used the later Service Manual illustration is the correct method of assembly.
It's good you have caught it and can repair it before it causes a problem.
If the o-ring the ball seats against have rotted and broken the valve will not shut off in that direction.
piclr60
Post by piclr60 »
Laughing out loud as I read the last post!
Pulled the valve out yesterday! Wow. Hope I don't have to do that again. I found out that one of my o-rings was out of the retainer on one side which was why I could not shut the fuel completely. Also I had no bushing in my valve at all. I could push the cam down but it was a fair amount of force in order to do so. Rebuilt the valve with the McFarlane rebuild kit and put the two washers George recommended instead of the bushing. When I put it back in I used nutplates to save me pain!! Seems to be holding fuel when I left. Will see if I have any fuel left in the airplane in the morning.
Thanks for all the help from everyone!
Brad
