Fuel Primer Lines / Fittings
Kyle
Post by Kyle »
I moved my post from another discussion...
I have been reviewing various links to treads discussing Fuel Primer Line Fittings. I'm a bit confused as to the part numbers for the fittings running from the firewall to the intake manifold and from the fuel strainer to the firewall. The only exception I've found this far is the nipple on the strainer p/n An816-2D. I know the lines themselves have part numbers, but the rest of the fitting are not in the IPC, or I just missed them.
Can anyone fill in the planks on the part number for the primer line fittings ?
Thanks in advance,
Kyle T.
Kyle Takakjian
Truro, MA
52 C-170B, N8087A
