I've searched and read numerous threads and I am trying to find a side by side photo comparison of the 8.50x6 vs 8.00x6. What speed difference have y'all that've used both noticed? I'm looking at primarily well-prepared grass runway with the occasional asphalt airport use. I'd like a tire that would lend itself to a little more flotation than the 6.00x6 when the ground is softer during the winter.
Thanks,
Rob
8.50x6 vs 8.00x6
Re: 8.50x6 vs 8.00x6
Rob,
From the description of your expected use you don't need 8.50 tires nor the hassle of their approval. 8x6 will be fine. Currently my 170 is based at a grass field that is not well prepared, but mowed for the most part and we are only using 7x6.
- n3833v
If i recall, someone posted some side by side pictures of the 8.50 & 8.00.
found: http://cessna170.org/forums/viewtopic.p ... 8.50+tires
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
- Heflin
Here you go. 6.00x6 (4 ply) 8.00x6 (4 ply) 8.50x6 (6 ply).
However, the 6.00's and 8.50's are air'd up to proper pressure. The 8.00's in the middle are not even mounted on wheels. I'm guessing the 8.00's would be about an inch taller if mounted and air'd up.
Tom
- Heflin
