Primer line leak
48RagwingPilot
Primer line leak
Post by 48RagwingPilot »
I have a leak in my copper primer line between the firewall and the intake manifold. I was hoping for an easy fix by simply fabricating a new copper line with flared fittings at each end. Come to find out the fitting at the manifold is concave (for lack of a better description) and will not accept the type of fitting I can make with my 37 degree flare tool. Perhaps it's a double-flare fitting? Anyhow, I removed the fitting from the manifold for a closer look and it has the appearance of a needle fitting one would use to inflate a football. I rarely use my primer but don't want it inop. Any thoughts on how to manufacture a new line? Thx.
48RagwingPilot
Re: Primer line leak
On further examination, the end that affixes to the primer nozzle appears to be soldered on. If so, are these soldered in the same manner as copper plumbing pipe? Thx.
Yes
48RagwingPilot
Thx. Parts are ordered and enroute.
