Indicated Air Speed Error
Onewinglo
Post by Onewinglo »
Guys I think my indicated air speed is a bit low. Is the airspeed indicator tested for accuracy during the static system check?
Thanks,
JP
C170A N1714D
My First Airplane!
DaveF
Re: Indicated Air Speed Error
Post by DaveF »
No, they only check the static system, but here's a way of checking it yourself:
http://www.rst-engr.com/rst/articles/KP89JUL.pdf
Onewinglo
Post by Onewinglo »
Thanks Dave! I think I'll give this a try.
JP
C170A N1714D
My First Airplane!
fshaw
Post by fshaw »
Any chance someone could post a picture of the pitot bend profile?
fshaw
Post by fshaw »
From what I can see in the online IPC I'm using, once I disconnect the pressure line from the airspeed indicator I can blow it clear with pressurized air. It appears all other instruments are downstream of the ASI. Is this correct?
Thanks.
Frank
Probably. I would still have to eye the line to insure it was going directly back out to the pitot before I blew anything through it. Just me.
imncntrl
Post by imncntrl »
In the manual stated above. Page 16-9. Figure 16-3. I've attempted to attach the page, but its too large. I re-bent mine to match after wing cover issues. I think it worked well.
Jared N5786C
