Scott Tail Wheel torques
- DMACJR
Anyone know if there is a specific torque for the mounting of the Scott tail wheel assy to the leaf spring assy or is it just standard torque for the appropriate bolt size? Also anyone know what the bolt torque ss for mounting the leaf spring assy to the airframe mounting bracket or is it also the standard torque for the appropriate bolt size???
- n3833v
Re: Scott Tail Wheel torques
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
- DMACJR
John, thanks for the info link, great stuff, good reading, but still did not give me what the bolt torques should be....still on the hunt....
Use standard torque for an AN-7 and account for the lock nut when doing it.
Use standard torque for an AN-7 in tension, 450-500 inch pounds and account for the lock nut when doing it.
- mit
Tighter the better can't tell you how often I have found them loose.
So how much over standard torque would you over torque a bolt known to snap to make it tight enough till it snaps?mit wrote:Tighter the better can't tell you how often I have found them loose.
- mit
I knew that was coming! Also to make sure the spring is tight in the grove on the tail wheel the looser they are the more likely they get loose when you use the standard torque.Bruce Fenstermacher wrote:So how much over standard torque would you over torque a bolt known to snap to make it tight enough till it snaps?mit wrote:Tighter the better can't tell you how often I have found them loose.
Looks like the secret handshake is still safe.
Could the bolt be stretching ?
CHECK THE SHANK-LENGTH ON THAT BOLT.... and make certain that you have sufficient washers (and threads) to prevent the nut from tightening down on the shank! No matter how much torque you place on it.... it won't stay put if it's run out of threads! (I.E., the entire BOLT may be rotating...not just the nut.)
Make sure it's a steel lock nut vs nylon. The latter seem to work loose.mit wrote:Tighter the better can't tell you how often I have found them loose.
Before over torquing, I'd consider some locktite.
I put some torque seal on mine so I can visually check it during preflight.
I personally have concluded that the nylok nuts are just fine....and metal lock nuts not an absolute requirement...as long as the eyebolt length is considered. After placing an extra washer beneath the nut, the rotation completely stopped.
