Hopefully this is in the correct area,
Just saw a set of Cleveland Double Puck Brakes for sale, is there a specific model number to fit on a '56 C170B?
Model Number for Cleveland Dbl Puck Brakes
- wldlndfirefghtr
'56 170B N3526D
Re: Model Number for Cleveland Dbl Puck Brakes
I believe the number you want is 199-62.
rob is correct, 199-62 is the kit number, the brakes are 30-52N and the wheels are 40-75D, those are the 3 bolt wheels. These have the deeper off set brake disc and torque plates for 8.00 tires. You need the STC from faDodge to install.
- wldlndfirefghtr
Thanks for the info!
From the ad:
"Cleveland Double Puck Aircraft Brakes with backing plates. Pads in great shape and new o-rings. Model # 30-52N $450 for the pair".
Currently have 8.50x6's, someday like to upgrade to 26's, not sure if these were worth picking up.
Thanks.
From the ad:
Thanks.
'56 170B N3526D
- blueldr
I bought a complete set of serviceable double puck Cleveland brakes from an aircraft salvage yard for about $100.
Was that in the old gold certificates? or the newer silver certificates? ...or the latest "reserve notes"?blueldr wrote:I bought a complete set of serviceable double puck Cleveland brakes from an aircraft salvage yard for about $100.
- blueldr
It was a check drawn on the USAA Federal Savings Bank in San Antonio, TX.
