Your go to bar?
Your go to bar?
If you could only have one bucking bar, what would be the shape?
Of course, in tungsten do folks have a bar shape that they reach for 90% of the time?
Re: Your go to bar?
As ap AP for my airplanes only, I have three tungsten BB's, but this is my go to one: http://www.amazon.com/Tungsten-Bucking- ... ucking+bar
HTH,
Ron
HTH,
Ron
Re: Your go to bar?
The one I pick up 99% of the time on my RV-7 project is pretty much identical to this one on amazon.com. It's 5/8" x 1" x 4", weighs about a pound and a half, and there are very few places it won't go. I like the 15-degree angled face on one end, which allows the bar to fit all the way into the leading edge of the RV wing and still get a square shot at the buck tail.
- edbooth
Re: Your go to bar?
Having built four Van's RV type aircraft, approximately 90 percent of the time these were used. The smaller one is made of tungsten and costs about 100 bucks. The other one I bought used from "The Yard" in Wichita, KS for about 5 bucks. They both buck quite well.bagarre wrote:If you could only have one bucking bar, what would be the shape?
- johneeb
Re: Your go to bar?
Ed,
Is there some technique that you use when bucking rivets that the tape on the bars helps with?
- edbooth
Re: Your go to bar?
It's just a good practice to tape up the bar to protect the aluminum around where you are riveting. It also makes it easier to grasp the bar...you don't want to drop it and dent something that would not look good with a dent in it. If your riveting in an area where you suspect dropping would cause damage , always protect the area with cardboard, small pillow or something similar. Here is a pix of the assortment I have used. Oops both pix the same.johneeb wrote:Ed,
- Ryan Smith
Re: Your go to bar?
I had a different idea in mind when I read the post topic. This makes more sense, however.
- edbooth
Re: Your go to bar?
Here is the only one I have on iPad. Will try to dig up the other ones off the other computer..if I can remember how to use it.Aryana wrote:Some cool looking shapes in there and all well used...let's see some pics of those RVs someday Ed!
- johneeb
Re: Your go to bar?
Nice Ed! You seem to be partial to maroon and white!
- edbooth
Re: Your go to bar?
It's kind of similar to Red, so it has to be fast.johneeb wrote:Nice Ed! You seem to be partial to maroon and white!
Re: Your go to bar?
Yeah, my first thought for a response was Brewery Becker here in Brighton, MI, but this IS an airplane forum...Ryan Smith wrote:I had a different idea in mind when I read the post topic. This makes more sense, however.
- edbooth
Re: Your go to bar?
The "Bars" are at this Bar.cessna170bdriver wrote:Yeah, my first thought for a response was Brewery Becker here in Brighton, MI, but this IS an airplane forum...Ryan Smith wrote:I had a different idea in mind when I read the post topic. This makes more sense, however.
Re: Your go to bar?
Thanks! This was a really helpful thread.
Going with this one:
http://www.amazon.com/gp/product/B00XZB ... H3BMNHQNU0
Next up...rivet guns
Re: Your go to bar?
Tungsten has its uses, however don't ever drop it in a hard to get to area. It cannot be retrieved with a magnet like steel ones can. Occasionally one does drop a bar
- gfeher
Re: Your go to bar?
Dave, Just curious. Did you settle on a rivet gun?bagarre wrote:Next up...rivet guns
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
