Bellcrank bearing
- edbooth
Bellcrank bearing
Does anyone know the number of,or, what type of bearing is used at the rear elevator bellcrank attach bolt ? When grabbing it through the inspection hole there is zero up and down movement but there is some lateral play, maybe a quarter inch each way. Just wonder if that is normal.
- edbooth
Re: Bellcrank bearing
Thank you man... That helps.Aryana wrote:Here's a thread that has some info Ed.
