Broken Parts
- Karl Towle
Broken Parts
I thought it might be interesting to start a thread showing broken parts "horror stories." Let's hear about parts that have broken, the stories of how they were discovered, and pictures if possible.
This one didn't happen to me, but Sal Buentello, my "cylinder" guy in Prosper Texas showed the part to me. He says it came from a running O-300, discovered via a suspicious compression check. Here's a picture of a piston from the top: Note the barely visible crack across the entire top of the piston. The crack went all the way around and through the skirt, at right angles to the wrist pin. Here's a picture looking through the gap: He said the cylinder would actually make compression - intermittently.
- 170C
Re: Broken Parts
Get Steve Grimsley to post photos and his story that occurred during our 2013 convention in Bardstown, KY.
- sfarringer
Re: Broken Parts
I can't prove it, but I believe it was due to a bad batch of autofuel from Farm Bureau Co-op. Rod bearings had signs of detonation.
Ragwing S/N 18073
- blueldr
Re: Broken Parts
I'm at a loss to undrstand the above. Please tell me how rod bearings are likely to show detonation.
- 4583C
Re: Broken Parts
Frank170C wrote:Get Steve Grimsley to post photos and his story that occurred during our 2013 convention in Bardstown, KY.
If Steve has ever been on the forum I don't remember it, but I do happen to have the incrimingating photos. Can anyone come up with a pic of a case of worse "broken parts" that didn't include major airframe damage?
Re: Broken Parts
OK, this one did involve some airframe damage; a Cherokee 140 prop leading edge fits nicely in the crease...
The majority of the broken stuff in the first photo is being replaced, however here's one part that through the magic of annealing and some well-placed hammer blows, Mountain Airframe was able to resurrect:
- johneeb
Re: Broken Parts
I know this is a Lycoming, it belongs to a buddy on his 500 Aero Commander. He was on his way to Peoria, IL to drop off the airplane for its annual inspection and have the engines majored. It blew up about 15 minutes short PIA, landing occurred without further incident although a little later then planned.
- sfarringer
Re: Broken Parts
The rod bearings showed classic visual signs of overload, and detonation is one thing that can cause that. Overloading rod bearings in an O-300 with a fixed pitch prop is not a common problem.blueldr wrote:I'm at a loss to undrstand the above. Please tell me how rod bearings are likely to show detonation.
Ragwing S/N 18073
- 4583C
Re: Broken Parts
Some airframe damage???cessna170bdriver wrote:OK, this one did involve some airframe damage; a Cherokee 140 prop leading edge fits nicely in the crease...
Re: Broken Parts
I think that in the engine category, Steve's engine will take a prize in any contest. And it was still running after he landed. Steve used it to taxi into the parking spot.
As for airframe damage, well Miles, the picture of your aircraft is pretty hard to beat. And to think your aircraft wasn't even in motion.
Re: Broken Parts
Thanks Paul for reminding us, I had forgotten had bad that hit was. With a pic of the finished plane, the two together would make an excellent ad for Del's shop.
Re: Broken Parts
It's easier to joke about it now...4583C wrote:Some airframe damage???cessna170bdriver wrote:OK, this one did involve some airframe damage; a Cherokee 140 prop leading edge fits nicely in the crease...
