Shortest U-Haul
Shortest U-Haul
Has anyone ever shipped a 170 fuselage in a U-Haul or other rented truck?
I have a wingless, tailless, motorless fuselage that I think comes in at 16 feet.
I need to get it from Pittsburgh to Virginia.
Is it too crazy to hitch the tailwheel and tow it backwards on the mains with trailer lights on it?
Re: Shortest U-Haul
On this forum a long time ago, where pictures of a 170 with the wings and elevator removed, shipped in a U-Haul truck.
Trailer it on it's own wheels. Yes that is crazy and illegal in PA where trailers must be licensed. But you could easily trailer that on a 16 ft utility trailer.
Re: Shortest U-Haul
I wasn't sure if it was legal or not. I remember my dad towing his Cassutt that way but it was 1977 and back country roads.Bruce Fenstermacher wrote:On this forum a long time ago, where pictures of a 170 with the wings and elevator removed, shipped in a U-Haul truck.
A 16' open trailer would hold the plane but I dont have anything to tow the 16' trailer with.
I'm leaning towards the 20 truck they have so I can stuff the cowling, horizontal stab and ailerons in as well.
Re: Shortest U-Haul
I transported my 48 in a uhaul years ago from MI to TN. I have also hauled one on a 16 ft trailer.
- 170C
Re: Shortest U-Haul
I would recommend renting the enclosed U-Haul truck. That way everything is inside, out of harms way short of a collision or overturn of the truck. Just my opinion.
Re: Shortest U-Haul
That closed truck is a very good idea. Protects everything. I helped a friend transport a cessna 182 [ 2001 model] with out wings and tail feathers from the state of Washington to montana and and the number of times we were stopped by the police and asked questions and viewed the purchase receipts was unbelievable . the fuselage was strapped to a very large trailer . The questions asked wasnt about the load itself but the aircraft and the history of the ownership. By the end of the journey we were wondering what was this aircraft previously used for ? My friend purchased the "aircraft "at a public auction. It had a near new engine and prop but the wings and tail feathers were missing . PLus the log books were in the cargo area. To me it was a steal. OOps" Shouldn't use that word. So I would have a enclosed van type of truck to move my aircraft and its bits and pieces.
- 170C
Re: Shortest U-Haul
Hopefully some of our members, who have moved aircraft via U-Haul type trucks, will chime in and give you some input on how their experiences have been. Those that have been there and done that are much better qualified to address the pros and cons of such a move than those,like me, who have been fortunate enough not to have done so.
Good luck
Good luck
Re: Shortest U-Haul
The biggest issue is the gear when transporting. Too wide to fit between the axles on trailers, and too wide to fit into the door opening in a box.
Early gear can be cranked in to pass through the door opening then relaxed for the ride. Lady legs are too stiff for that technique to work. Have on hand 1 foot long bolts, make up spacers and mount the axle on the inside of the gear. With one wheel riding inside of the leg, the plane will just fit.
Most airframes will just fit into the box past the top of the door by utilizing the slant of the windshield. To do so tail in, the gear is raised just before the door opening, then as the tail is lowered the top of the fuselage enters the box then the gear / plane is raised.
You can flat bed it but you need a way to get it up there on the bed. With no engine and stripped likely a sling and small fork truck will make quick work of the job.
- 170C
Re: Shortest U-Haul
That is what I was hoping for Jim, but didn't want to single you out unless you chose to do so. Your experience is worth tons to someone trying to decide which way to go
Re: Shortest U-Haul
Some more ideas http://www.cessna170.org/forums/viewtop ... ser#p45127
Re: Shortest U-Haul
Already set for the gear. Have a firewall mount that it will roll on so the gear comes off before shipping.
Re: Shortest U-Haul
I've always kept the tires on to absorb the bumps along the way. I guess you could go "hardtail" but I would't want to go far and certainly would't do it if the instruments were still installed. Then again if its a few blocks who cares. My last (and hopefully last) haul was 2000 miles and even when strapped down, the fuselage did move about.
Re: Shortest U-Haul
Jim
