weight and balance app
cvj774
Post by cvj774 »
Is there an app for weight and balance ? If not, is there a spread sheet template?
Carl
Re: weight and balance app
There are apps the can be adapted such as the W&B part of ForeFlight, but none that I know will work well specifically for the 170 as the spreads I created a long long time ago. You can find them here:
http://www.cessna170.org/forums/viewtop ... 26&t=10379
rickyricky2
Post by rickyricky2 »
I use Aviation W&B Calculator by Roy Kronefeld on my I phone.
Dick Bryant
N2704C
jyokom
Post by jyokom »
Bruce Fenstermacher wrote:There are apps the can be adapted such as the W&B part of ForeFlight, but none that I know will work well specifically for the 170 as the spreads I created a long long time ago. You can find them here:
Your Link doesn't appear to work now. Can I get a copy of your Excel docs?
'50 170A 19204 N9743A
I believe Ol’ Gar had a program he said worked well… something along the lines of …”if the tail won’t come up off the ground before the end of the runway, the CG ain’t keerect!”
pdb
Post by pdb »
Here is my W&B. You will have to modify it for your particular model and aircraft.
1) The weight limits for normal and utility operations, as well as the limits for CG and the moments of seat, baggage , and fuel come from the FAA’s TCDS.
2) The empty weight was prepared and equipment list for my plane was prepared by my mechanic weighing the airplane. The calculations are no better than the data on which they are based. Is your current and correct?
The sample calculation attached shows how mine looks at max gross with full fuel, two fat guys up front, a slender person in back, and a limited amount of baggage in the rear and extended baggage areas. The CG is right in the center of the range permitted in the normal category. The Cessna engineers did a great job designing a useful airplane.
It’s good to know that if I get in the plane solo, have no baggage, and have full tanks, the CG is forward of the forward limit. It’s illegal to operate and more importantly, it’s potentially hazardous.
It’s difficult to get a conventionally configured 170B aft loaded though I am sure some creative types can do so. However, I have a very nice extended baggage and that makes it much easier to get it aft loaded. Imagine coming in heavy, aft loaded, and slowly and then discovering you inadvertently stall the plane and lack elevator authority to lower the nose. (h/t John )
N4563C W&B 12-20-19.xlsx
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
johneeb
Post by johneeb »
pdb wrote:....................................... Imagine coming in heavy, aft loaded, and slowly and then discovering you lack elevator authority to raise the nose.
Peeeeete
pdb
Post by pdb »
John…. I am a moron, I will correct it. Thanks.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
mmcmillan2
Post by mmcmillan2 »
I made one for Garmin Pilot. I may be able to share it if you use that app.
rnealon1
Post by rnealon1 »
FltPlan.com website and FltPlan Go app (both free) have a weight and balance tool with well over 1000 aircraft including all 170 models.
Bob Nealon
Southbury, CT
jyokom
Post by jyokom »
I made a new one in Excel, glad to share it. I use Foreflight now.
Rotorhead
Post by Rotorhead »
