Franklin 165
TFA170
Franklin 165
Post by TFA170 »
I was looking up some info about something else and stumbled upon a post claiming the Franklin 165 was listed in the TCDS, so I checked the TCDS and it is indeed listed as an optional engine for the 170!
A quick wikipedia search shows about a 40lb difference in listed dry weights, but I have no idea if those are comparable weights or not...I'd have thought it would be heavier still.
Does anyone here have a 170 with a Franklin in it?
Re: Franklin 165
There are still a few out there but I don't think anyone will ever convert any other engine over to a Franklin. The expense and varied problems with the Franklin would not be worth it.
beaverbill
Re: Franklin 165
Post by beaverbill »
I recently flew a 1952 B model with the 165 Franklin engine. Interestingly enough, that particular airplane was converted to the Franklin when it was only about 6 months old. Apparently the owner specifically wanted that engine "upgrade". And, 65 years later it is still motoring along.
Re: Franklin 165
Many years ago we had a bell 47 with a franklin engine in it and it was really reliable .a little under powered but left lycoming behind in reliabity. However obtaining parts was spasmodic and the aircraft was refitted with a Lycoming engine .About 5 years ago I saw a Cessna 170b with a 220hp franklin fitted . I was told it went like a rocket ship. Again they had issues with parts and where they were going to be built .this aircraft was painted a bright yellow so I am sure other members would have seen it also .
