I am having a issue with CHT,s that for some time I didn’t know I had . Originally when the 180 hp 4 banger was fittted I had only 1 CHT probe on the hottest cylinder . That being no.3 . The single probe EGT was fitted to the cylinder opposite . Every thing appeared to work well . Then another STC had to be fitted . This was the EI 4 probe CHT. The ground run after fitment was satisfactory. I then had to do a flight under some very trying conditions and decided to keep a close eye on CHT,s and see what was happening to the other cylinders . Shock!!! . There was a difference of 100 degs between the hottest and coldest cylinder . The coldest was 293degs and the hottest was 393 degs . Normally at altitude [7500ft] and at 2550 rpm the hottest cylinder would run running at 340 degs. It was a extreme day for flight ,hot and massive turbulence and engine power was constantly being changed . [and altitude]
My ‘BLUE’ silicone baffle seals are as in new condition and seal well. The pressure in the lower cowl is constant with the exception of near the out let . I have heard stories from others that the intakes are not correctly designed. So my question is ..... has any body else with the 4 banger up front had any issues similar to mine . I have some radical ideas , [george is rolling his eyes again ] . So the research has now started .
Absolutely , or at least with mine temps are all over the place until I dial in the EGT: I can tell when I’m close to the best lean point, rich of peak, all the EGT’s start to line up and subsequently the head temp differences narrow. 0-320 B3B
ghostflyer wrote:I am having a issue with CHT,s that for some time I didn’t know I had . Originally when the 180 hp 4 banger was fittted I had only 1 CHT probe on the hottest cylinder . That being no.3 . The single probe EGT was fitted to the cylinder opposite . Every thing appeared to work well . Then another STC had to be fitted . This was the EI 4 probe CHT. The ground run after fitment was satisfactory. I then had to do a flight under some very trying conditions and decided to keep a close eye on CHT,s and see what was happening to the other cylinders . Shock!!! . There was a difference of 100 degs between the hottest and coldest cylinder . The coldest was 293degs and the hottest was 393 degs . Normally at altitude [7500ft] and at 2550 rpm the hottest cylinder would run running at 340 degs. It was a extreme day for flight ,hot and massive turbulence and engine power was constantly being changed . [and altitude]
The typical IO-360 has an upper cylinder limit of 500-degrees Fahrenheit. If the hottest you observe is 393 you are in good shape (although some baffling might still be questionable if the spread amongst cylinders is great.)
My O-360 usually runs hottest on number 3, but no more than 50° difference between hottest and coolest. Normally about 20 in cruise. I rarely exceed 380° and absolutely never exceed 400.
After the engine overhaul I was seeing CHTs of 400-420°, but they came down over about the next 100 hours, and have continued to decline slowly, now at 350 hours. I spent a lot of effort trying to fix the baffling, but it made no difference at all. I think the biggest effect on CHT is mixture, specifically, maldistribution among cylinders. I think the Avcon carb airbox in my airplane is a poor design that puts a nonuniform air flow into the carb, so small changes in throttle position have a large effect on how the fuel is atomized and distributed. For example, takeoff at full throttle gives EGTs and CHTs much higher on 3 and 4 (rear cyls running lean) than 1 and 2 , but pulling the throttle back 1/4" evens out the temperatures a lot, with no loss of MP. I know, I should let the economizer do its job, but the JPI shows that this works. Also, rolling back the RPM to 2500 helps. Back in the '60s Mooney and Piper put a set of flow-straightening vanes in their O-360 airbox outlets, and a bunch of RV guys have reported improved cylinder uniformity doing the same. I haven't tried it.
Something else to try is converting the carburetor from a 10-3878 to a 10-3878M, or swap to a 10-4164-1. The 3878M is the 3878 with an improved main jet, and the 4164 is the factory-new designation. All are approved for the O-360. The conversion kit (Marvel-Schebler p/n 666-660) was introduced in the 1960s in response to Mooneys running high CHT, hence the "M". I haven't tried this, either.
When I was first troubleshooting the CHTs by fixing baffling I tried blocking off the cabin air inlet. It's a 3-inch hole in the baffle wall behind cyl 3. You'd think that closing a 7 sq. in. hole in the baffling would make a difference, but it didn't at all! I'm guessing, because I haven't measured it, that the lower cowl pressure is too high and there's not enough delta-P across the cylinders, but the upper side has plenty of pressure, so messing with the upper side won't fix it. I might need a larger lower cowl lip to lower the outlet pressure.
I've also found that in climb, my CHTs are lower at 65mph indicated than at 80. Counterintuitive, but I assume the change in deck angle influences the upper/lower pressure delta. Works for me, though, because I get much better rate of climb at 65 than at 80. I also found that the MT propeller gives lower CHTs in climb than the Hartzell did. I don't know if it's an airflow difference or just due to the improved ROC, but I can do landing and instrument approach practice on the hottest days in the summer without exceeding 400.
Ghost, I know you've done some fancy cowl mods, and I'll be interested to see what you find.
Thankyou gents for the update and advice. Firstly the engine baffling fits really well and seals excellent. Initially I placed a very strong light in the intakes [done in a dark hangar] and checked for light escaping on joins and sealing surfaces. Then I placed a very small camera in the intake looking at all the seals and went for a fly .all good . . NOW, these seals are BLUE so they keep up with the aeroplane . . I will look at my main jet but I am very happy with my carburettor and it’s operation at the moment. I will try your leaning process.
My heater intake is before the LH intake to the engine so it doesn’t upset the airflow that much . On the other intake [RH] I have a small 1.5ins in Dia duct the runs to the back bearing on the alternator .
However no1 cylinder is in direct blast of air from the Lh intake and no3 cylinder gets what’s left over . I have been talking to a friend at cessna he suggested I have a look at the new Cessna 182,s intake [ I have been looking at it before he mentioned it] . The duct rapidly curves upwards and runs about 8ins rearwards. I also feel my lower cowl is working well also.
[NB. My friend who works at Cessna only advises me in his free time for entertainment reasons only , he is a qualified aeronautical engineer . He has worked for a number of aviation companies on some big projects and some of his ideas are just rubbish ,I love to tell him that ,we are always having a go at each other. . He is a very funny guy when he has a few beers under his belt . ]
Cessna specifies Lip PN 0552001-60 on all floatplanes.
Years ago Lycoming issued Service Bulletin 258 for the O-320. I’ve read that diameter between the intake manifold and the carb is doesn’t match on the O-360 either. Something to consider for more even fuel flow?
