'48 fuel cap gasket
- Bill Venohr
'48 fuel cap gasket
Has anyone found a source, or even material to make a gasket for the fuel cap on a '48 ragwing? I've tried several things, but they didn't seal very well or reacted to the fuel and curled.
Bill Venohr
N4044V
Aurora, CO
N4044V
Aurora, CO
- N1478D
Ordered two extra oil cap gaskets from http://www.realgaskets.com for the gas caps, they work great. Been real happy with them.
The oil cap gasket has worked well too.
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
I can't imagine why you wouldn't simply order the correct part from Cessna distributors, :0322551 GASKET
(List Price: $ 71.40) YOUR price=== $ 60.69 (EA)
Try ordering from Aircraft Spruce 877-477-7823, PN: FC2651 (fits A/B models) for $1.50.
All you A & B guys--be advised that the ragwing (1948) model fuel caps are completely different from the later model 170's,also different from the 120/140 for some reason,even though the ragwing tanks are apparently 12.5 gallon 120/140 tanks (left-overs?). According to my 1948 IPC,the fuel cap gasket is p/n 0522538.
As far as A & B gaskets go,I'm not too sure that your part number is correct George. That gasket is for Spruce's "bayonet fuel caps and filler necks" set. They list a Cessna gas tank gasket p/n 05-18505 (2-1/4"OD,1-3/8"ID)for $5.95 in my year-old catalog.
The 170 ragwing IPC pg 7, shows item 3-18 "fuel cap gasket" as PN 322538, which has been superceded to PN 322551 (the one I previously listed so outrageously priced at Cessna.)
For the corresponding Aircraft Spruce PN FC2651, I relied on N1478D's comment that the oil cap gasket also works. I should have known better than to accept the word of a certain flat-winger regarding a part for a real airplane.
What is the outside/inside diameter and thickness of the gasket for a ragwing?
- N1478D
Now George, all I said was what I ordered. The fact that I fly an A is listed in all of my posts! A straight-winger is much more accurate. Your wing is as flat as mine, and, of course, the slowest wing of all.gahorn wrote:The 170 ragwing IPC pg 7, shows item 3-18 "fuel cap gasket" as PN 322538, which has been superceded to PN 322551 (the one I previously listed so outrageously priced at Cessna.)
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
I checked the 1948 IPC--item 3-18 is indeed listed as "p/n 0322538: gasket--fuel tank cap". Hopwever,check page 15,for the RIGHT wing structure--item 7-10 is listed as "p/n 0522538: gasket,fuel tank cap". My LH & RH caps are identical,I assume that the gaskets would be identical also. I assume one of these numbers is a typo,especially given the similarity of the part numbers--only the second number is different (one's a 3,one's a 5).gahorn wrote:The 170 ragwing IPC pg 7, shows item 3-18 "fuel cap gasket" as PN 322538, which has been superceded to PN 322551 (the one I previously listed so outrageously priced at Cessna.)
Where did you get the information regarding the gasket part number being superceded to 322551?
Last edited by zero.one.victor on Fri Feb 06, 2004 6:11 am, edited 1 time in total.
A check at http://cessnaparts.com/parts.cfm listing the pn's desired will retrieve from Cessna's ICT warehouse the current inventory on hand. (The website is maintained by Hill Aircraft, a Cessna Distributor, but the search engine is a direct link to Cessna.)
The results will be the number on hand, suggested retail price, YOUR not-so-heavily discounted price, and/or the superceded PN, which when clicked upon, will renew the search for that superceded part number.
What are the dimensions of the ragwing gasket?
Re: '48 fuel cap gasket
Thanks to Bill K; 3958V, I found Real Gaskets Tennessee @ 1-800-635-7325 and found the right size gaskets for $15.50 each part # RG-2551). They are twice the thickness of my existing gaskets but I might bet the ones installed might have been replaced at least once before in the last 66 yrs.
