brake calipers ?
butchpilot170
brake calipers ?
Post by butchpilot170 »
Hi ! Anyone know if the Cleveland 30-63a brake caliper is interchangeable with the 30-75a caliper ? Thx !
Re: brake calipers ?
butchpilot170 wrote:Hi ! Anyone know if the Cleveland 30-63a brake caliper is interchangeable with the 30-75a caliper ? Thx !
Although they both were applied to C-172's dependant upon serial number (and a few others) ...they use different cylinder assy's (calipers). The 30-63A uses PNs 091-02200, -15900, -05000, -08400, -11900, and-12200 calipers (cyl. assys) ...while the 30-75A uses-04400 and -06400 assy's. The actual differences are difficult to be identified in the Cleveland parts depictions, (various small parts and fitment) but they are different or they'd have the same PNs. One big difference, among many is they use different pistons. (Doesn't mean you can't make 'em fit..but the legality would come into question.)
They utilize different wheels as well as different discs...and different torque-plates.
So...despite their similarities in appearance...they are not the same.
Hope this helps.
butchpilot170
Thank you Sir for that info ! Maybe someone in the club has a good used one collecting dust while on the shelf ! the ButchPilot !
Post by 99654 »
Butchpilot, I sent you a pm. Please check your messages.
