How do you guys run cables (COAX) from your radio install to antennae on the belly. I have a lower antennae that does not have a COAX going to it. The previous install ran through a modified (butchered) inspection plate in the floor. This left an unsightly hump in the carpet just behind the pilots pedals. I can't find a way to pass the COAX through the gear box bulkheads or down the door post structure.
Thanks in advance.
Cable routing
Cable routing
Fly safe!
Vern
1950 C-170A N5453C sn 19487
Based in Pensacola, FL. 82J
Vern
- n2582d
Re: Cable routing
Vern,
After s/n 25372 Cessna added a small plate with a grommet in the left floorboard as shown in fig. 20 of the 170B IPC: Would this work for your cable routing? As the coax will likely pass near hydraulic brake lines, fuel lines and flight control cables it's imperative that the coax be adequately secured as it snakes it's way from radio/transponder to antenna. Dave has done a lot of research into cable harnesses here.
Re: Cable routing
Gary,
Mine is an A sn 19487. I don't recall seeing anything like that in my floor.
Fly safe!
Vern
Vern
- n2582d
Re: Cable routing
It would be a minor alteration to cut out a similar hole and make a cover as depicted above.
Re: Cable routing
...or use a "Unibit" to cut a small hole and use a grommet to prevent chafeing of the coax. This plate Gary showed (and the hole I suggested) is behind the side-panel upholstery. Just laying any type or wiring beneath carpet is not a good idea because stepping on it can damage/short it.n2582d wrote:It would be a minor alteration to cut out a similar hole and make a cover as depicted above.
