Annual Inspection Anomaly
MoonlightVFR
Post by MoonlightVFR »
I have owned N2890C for many decades.
Many different A/P IAs.
Have avoided ever commenting on their judgement shortcomings. Mostly pleasant experiences.
But I have some concerns.
My firm belief that an "inspection is an inspection". Not a contract that approves any unauthorized removal of parts.
I see no reason for sniping the safety wire on prop bolts. Thinking that a mirror check on back side of crank flange for crack is sufficient.
gradyb, '54 B N2890C
Re: Annual Inspection Anomaly
If the prop hub / crank flange / spinner bulkhead needs inspection for corrosion/cracks there's only one way to remove those bolts to inspect the area. Smoking bolt holes require inspection and torque-check.
