Carpet or Vinyl for a floor covering
Hawkeyenfo
Post by Hawkeyenfo »
Took out the original carpet on my last annual and have been flying without anything for a while. Looking to put something back in and found custom cut, vinyl floor covering from SCS-interiors. Has anyone used it, seen it used? Seems nice, easily cleaned, and easy to remove. SCS also makes carpet in lightweight, nylon and wool....all with burn certs. Thoughts???
Fly Navy !!!!
1941 Boeing PT-13D Stearman
1952 Cessna 170B
1960 Piper Aztec (PA23-250)
Re: Carpet or Vinyl for a floor covering
Here's a link to their C-170 items: https://scs-interiors.com/collections/cessna-170
N2625U
Post by N2625U »
I've got a '63 172 and ordered the carpet from SCS and installed it about 5 years ago. I realize you're looking at the vinyl floor covering but the carpet I got fit perfectly and I'm well satisfied with it.
Hawkeyenfo
I'm open to carpet or vinyl, never thought about vinyl until a IA friend said he saw a 180 with it and he liked it. I'm used to carpet ;) C'mon, it lasted 67 years! Did you buy the backing for the carpet or, just put the carpet down?
Fly Navy !!!!
1952 Cessna 170B
N2625U
Post by N2625U »
Just got the carpet only, no backing to it.
Mapleflt
Post by Mapleflt »
It worth noting that the carpet is better then half the weight of the vinyl, 4.5 lbs as opposed to close to 10 lbs for the vinyl and its the "little" savings that add up to something much bigger in time.
wabuchanan
Post by wabuchanan »
This looks superb.
I have been looking for a good vinyl solution for some time. The carpet is threadbare so have been flying without it. Dragging mud/grass/ and dirt into the plane makes the vinyl a viable solution.
Thanks for the heads up.
1950 170A N5776C SN:19730
dogone
Post by dogone »
I put coin dot in mine. Made it 2 or 3 inches wider all round to go up sides. This collects dirt so it doesn't end up in belly. Probably in the 10 lb range. It is certified flame resistant.
archerw
Post by archerw »
dogone wrote:I put coin dot in mine. Made it 2 or 3 inches wider all round to go up sides. This collects dirt so it doesn't end up in belly. Probably in the 10 lb range. It is certified flame resistant.
Tell me more about this, ... what brand?.. what is your source? My carpet was like fiber tape in the sun for 20 years; just barely there.
barrymaas
Post by barrymaas »
I redid my interior this winter, including the vinyl 'dot' flooring. It's call Loncoin, made by Lonseal. I ordered it through an outfit in CA. Color is space gray. I think I ordered 7 feet (it comes wide, so you can trim the excess and double it up in the aft area).
Was on the fence about it for a while, but now that it's installed I love it. I travel mostly to a grass strip where our cabin is, so the carpet was getting pretty ugly with dirt and grass. No longer a problem!
Let me know if this pic is too small to see it, and I'll figure out how to post a better image.
daedaluscan
Post by daedaluscan »
https://ameriteakstore.com/collections/ ... l-flooring
This looks very reasonable. I have the same stuff, but I was given a long narrow roll. I simply did two sides, and they overlap in the baggage area. I prefer it to carpet.
Charlie
1956 170B C-GDRG #27019
Barrymass, do you have an issue with your heels catching on that floor covering? The shop that installed my new interior discarded the original scuff plates at the forward end of the cabin floor, and I refused to take the airplane until new ones had been fabricated and installed. Sometimes when you need rudder you need it NOW, and don’t have time to dislodge your heels from the floor, be it carpet or vinyl.
dogone
Post by dogone »
Archerw I just know it as coin dot. I am sure any floor covering place could get it. Like I said can be had with flame proof certification. I ordered a piece about 3 feet by eight. Then did the floor all in one. Different colors available I think. Looks like barrymass' . I also covered the tunnel with it. cut oversize then used heat gun to melt/soften to form. No glue used. Just put flap handle cut out on top of it and reinsert screws. Leave lots extra then cut after fitted.
