Fuel Transducer placement on Ragwing JPI FS450
Jaredpilot
Post by Jaredpilot »
I have just ordered a JPI 450 Flow scan instrument and I am reading over the installation guide. Can anyone tell me where they installed their transducer on the '48 Ragwing model with the engine driven fuel pump that we have installed. I am making sure that I am reading the instructions correctly and not overthinking the install. There are two install scenarios which I want to make certain I pick the correct method.
I believe I should elect to install utilizing the "All gravity Flow installations without fuel pump" option even though there is an engine driven fuel pump on the '48. The other scenario is "All pump fed carbureted and Fuel injected engines without vapor return lines." which I do not believe applies. Any input and suggestions is appreciated! Thank you all!
