I have a 1949 Cessna 170A. Looking to see if anyone has a way or recommendation for adding pitot heat to a certified 170A. Looking to make a nice little soft IFR bird. Also any additional recommendations for IFR equipment I’m definitely curious. Thanks in advance.
Austin
Pitot heat for 170A?
- IA DPE
Re: Pitot heat for 170A?
When you join the Association, you’ll have access to the Document Library which has some info on this.
1955 C170B N2993D s/n 26936
1986 DG-400 N9966C
1986 DG-400 N9966C
Very common to add the later common Cessna L shaped heated pitot. Our TIC170A members library has 337s. I don't know but wouldn't doubt Cessna may have a SB to add it to the early 172. You should probably have a 35 amp generator minimum to make it practical to use, maybe even to get past the electrical load requirement on installation.
A heated pitot is not a requirement for IFR BTW.
Thank you! I appreciate the info. I went ahead and joined. I currently have a Jasco alternator in it that i think will do the trick but I’ll double check. I’ve picked up ice a lot at well below the reported freezing level a fair amount in my local area so I would rather it for practical use.
- n2582d
The ORIGINAL (Cessna approved) heated pitot for the 170 was the Kollsman 518B-01 (aka “sharkfin”) such as is often found on C190s and C195s.
Here’s the Cessna Instructions in the MX Library:
viewtopic.php?f=36&t=15955
<edited 1/22>
<edited 1/22>
I’m trying to click on these links to see what heated pitot tube I need for my 1950 cessna 170A or if I need a drill approval but when I click on the blue highlighted areas it says I’m. It authorized to do so where can I go to find the pitot tube I need or do I need a stc or a field approval.
Tristenmulcaire wrote: ↑Sun Jul 28, 2024 3:14 am I’m trying to click on these links to see what heated pitot tube I need for my 1950 cessna 170A or if I need a drill approval but when I click on the blue highlighted areas it says I’m. It authorized to do so where can I go to find the pitot tube I need or do I need a stc or a field approval.
Just like the OP, it does not appear you are a TIC170A member. So you do not have privileges to follow the links to the material for your answer. You can join TIC170A here: https://cessna170.org/register/ Once you join, send the webmaster a message requesting your forum privileges be upgraded: webmaster@cessna170.org
The answer to your question is there is no STC that I'm aware of. This leaves you finding parts and getting a field approval OR you could follow the approved Cessna Service Instruction which we have in our technical library which was linked above. AK175-23D
