Continuously ponderous though I am, I’m curious if anyone has had the same thought process as I and found a way to mount a grain of wheat bulb into the case for the fuel gauges? I have a spare set of gauges that I could easily work with and figure a way to mount them, but I’d rather not re-invent the wheel if it’s not necessary.
I got the idea of putting lights there from Larry Cranton. He’s got post lights mounted, and while nice, I’d rather not go that route because it would require the fabrication of a mount.
I’m looking at some of these bulbs.
https://www.superbrightleds.com/moreinf ... /341/1288/
I have a tail position light from them since Whelen doesn’t make white Chroma bulbs, and my panel lights are from them as well. I’ve got some bulbs from Superbright LEDs in my Dad’s Bonanza dome light and they are phenomenal.
Internally Lit Fuel Gauges?
Re: Internally Lit Fuel Gauges?
I wonder if fiber-optics might be a solution for this project?
- Ryan Smith
I’d not considered, but I’m liking that idea better. I’ll research it.GAHorn wrote:I wonder if fiber-optics might be a solution for this project?
Thanks, George!
If your overhead instrument lighting is still operational a lucite or fiber-optic rod from there, behind the headliner over to the gauges might be a relatively simple solution.
If you’re set on illuminating the wing root fuel gauges, I would also prefer the idea of fiber optic over a light bulb. I know the needle in the original fuel gauges is magnetically driven and isolated from the tank, but I have seen fuel-stained headliners in that area, so the thought of electricity there makes me shudder a little. For as seldom as I refer to fuel gauges, I’d use a small pocket flashlight.
- Kyle Wolfe
cessna170bdriver wrote:I’d use a small pocket flashlight.
While I like the concept of being able to see those gauges at night, I’m even more tickled that I think like a ‘rocket scientist’ as I keep a small headlamp wrapped on one of my post lights!
Kyle
54 B N1932C
57 BMW Isetta
54 B N1932C
57 BMW Isetta
Well...channeling BluEldr here.... “There goes your excuse for running out of gas.”
