fuel tank wear strips
Posted: Sun Jan 31, 2021 7:35 pm
by frfsgpo1
Anybody know what adhesive is used to glue down/ attach fuel tank wear strips.?
Re: fuel tank wear strips
Posted: Sun Jan 31, 2021 7:36 pm
by frfsgpo1
Searched for this topic in forum before posting.
Posted: Mon Feb 01, 2021 3:13 am
3-M 1300-L is often used universally on aircraft, but I don’t know what specified adhesive in this particular use.
Posted: Tue Feb 02, 2021 12:18 am
by frfsgpo1
Posted: Tue Feb 02, 2021 3:39 pm
by hilltop170
This is kind of a smart-a$$ remark, but not completely. If you could find out what that black sound-deadening material is that Cessna sprayed on the skin inside the fuselage, I would use that. It is almost physically impossible to remove short of grinding and it is not soluble in ANY solvent normally used in an aircraft maintenance shop.
Seriously, there are some commercially available adhesives that are gasoline-proof. I googled “gasoline-proof adhesives” and quite a few popped up that will be locally available to you at auto supply or big box stores. Good luck.
Posted: Tue Feb 02, 2021 4:32 pm
by Metal Master
hilltop170 wrote:This is kind of a smart-a$$ remark, but not completely. If you could find out what that black sound-deadening material is that Cessna sprayed on the skin inside the fuselage, I would use that. It is almost physically impossible to remove short of grinding and it is not soluble in ANY solvent normally used in an aircraft maintenance shop.
When reskinning my stabilizers which were coated with that black tar stuff inside. I found the best removal solvent was low grade Regular gasoline. Almost nothing else worked as well not lacquer thinner or MEK
Posted: Wed Feb 03, 2021 7:49 pm
Pickup truck bed-liner spray was what I saw on a 206 floorboards one time down in Alice, TX. They were a freight operation.
