Ideal Temps?
reecewallace
Ideal Temps?
Post by reecewallace »
Hi all,
What are the ideal temps for the following?
- EGT?
- CHT?
- Oil temp?
Mine are running the following temps once I've properly leaned:
EGT - 1380
CHT - 340
Oil - 200
These are my standard temps once I've leaned on the richer end. My oil temp seems high.
*Note - my oil pressure gauge has always shown high, and this is normal for my engines operation
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
DaveF
Re: Ideal Temps?
Post by DaveF »
Looks good to me.
Re: Ideal Temps?
Mine runs about 1450 EGT/ 350 CHT on the warmest cylinder (#2). That’s on an O-300A at 24.5 - 25 in. Hg manifold pressure and 2600 rpm, leaned for cruise.
Re: Ideal Temps?
Reece, your indications look very normal. Your oil press is actually allowed to go up to 50-55 without issue and your 45 is excellent. (The best judgment is when oil is hot and engine is at idle ... if the oil press is still above 5 it’s acceptable but if it’s above 20 that’s great!
