I have 175 wings on my 170B and was wondering if anyone could tell me the approximate quantity difference seen on the gauge between level flight and sitting on the ground in a 3 point stance. Tanks half full as a reference. I've got a couple sending units that need replacement so I don't trust any numbers I see. Also, I've searched posts but have been unable to find any references for setting nose to tail level flight on the ground.
Keith
Fuel quantity: level flight vs 3 point ground stance
- pdb
Re: Fuel quantity: level flight vs 3 point ground stance
I have no idea about the tank capacity but the TCDS says the following about leveling.
Specifications Pertinent to All Models…
Datum Leveling Means Certification Basis: Front face of firewall Upper door sill
I don’t see why you couldn’t level the airplane with empty tanks per above and then add gas incrementally, comparing the gauge reading with known quantity added.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
Anchorage, Alaska
N4563C 1953 170B
The only specification required by FAA is that when the tanks are empty of useable fuel….the gauges must indicate “Empty”.
I will posit only that since a 175 is a tricycle airplane the unsusable fuel must indicate “Empty” in the tricycle stance. Installation of those tanks into a conventional geared airplane would likely require they meet the standard for a tailwheel/tail-low “empty” condition. (I’d not be surprised to hear that this may have some relationship to the “No TakeOff” range on tailwheel airplanes since “unuseable” fuel may appear to be a greater quantity in the 3-point stance.)
Thanks for that answer!pdb wrote:I have no idea about the tank capacity but the TCDS says the following about leveling.
Maybe I didn't state the rest of my question clearly.
On a stock 170B wing indicating 10 gallons per side in a 3 point stance, typically how much higher will it indicate at a level flight attitude. 1 gallon? 3?
K
- pdb
Keith,
I understood your question but I don’t know the answer off the top of my head. I have the original gauges which are marked in quarters of a tank, not gallons, and aren’t that accurate anyway.
Pete
Pete
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
Anchorage, Alaska
N4563C 1953 170B
I was confused by the format Pete posted the leveling means of all 170 models. I had to look at it 5 times.
The datum, which you didn't ask for, is the front face of the firewall.
To level all models of 170 you level the upper door sill.
