Does anyone have info on an STC to replace an 0-300 with a 0-360 or I0-360 in a 1960 C-172A? Yes I know it's not a 170 but it has the same engine which I'll put up for sale here if it works out.
-Marc
STC to replace an 0300 with a LYC 0-360
Re: STC to replace an 0300 with a LYC 0-360
Well Marc…. I realize you asked about a 172-A. The Air Plains folks have the STC and perform the conversion of an O-360 or IO-360 (Lycoming) into the 172 B and C (and others). It’s probably not listed for the “A’’ because no one asked for it. Chances are they can get approval for your airplane,… have you contacted them?Plummit wrote:Does anyone have info on an STC to replace an 0-300 with a 0-360 or I0-360 in a 1960 C-172A? Yes I know it's not a 170 but it has the same engine which I'll put up for sale here if it works out.
-Marc
OR…are you wanting the Contenental engine…which can go by the same nomenclature “IO-360”…??
https://www.airplains.com/cessna-172-b- ... s#overview
If you are meaning the Continental engine…you might give Tailwheel Tom a call…. but be sitting down when you check the prices. It’s rumored he is hoping to retire on this conversion.
- n2582d
Marc,
Here's a couple of links for you to research:
Stoots IO-370
Del-Air's O-360
Kenmore Air Harbor. Here's their website.
Avcon. Search terms such as "Williams", "Avcon", and "Udall" on this website. A lot of information can be found here regarding this STC.
STC SA00728SE Anderson’s Continental IO-360 AML The Landing Gear Works
Good Luck
Stoots IO-370
Del-Air's O-360
Good Luck
