Hooker Shoulder belts for 170B
Richgj3
Post by Richgj3 »
I’m trying to understand the installation for the hooker belts. I have a request in to them. I understand the BAS installation requirements and know the advantage of inertial reel over fixed/adjustable belts. I had fixed belts in my 1958 170C (Bolen Conversion for 172) and I was fine with them.
If anyone has installed the Hooker belts could you describe the drilling requirements? My airplane has the nut plate installed from the factory.
Re: Hooker Shoulder belts for 170B
The STC’d Hooker Harness kit comes with detailed instructions. Basically, it involves installing a bracket onto the rear spar carry-thru at the same point as the factory anchor-nut, but instead of drilling a hole thru the top cabin skin, one rivets the bracket to the rear spar. (i’ve slept since I read the instructs but somewhere out in my hangar I’ve got those instructs and I’ll try to find them and post them.)
WHOOPS… No need… I see Bruce posted it in the Mx Library: viewtopic.php?f=41&t=9428&p=84057&hilit=Hooker#p84057
Richgj3
Post by Richgj3 »
Thanks George and Bruce!
