I’m not seeing anything in the Continental M-O for specific torques for the generator and tach drive studs. Can anyone help me figure out what torques apply? I just replaced tach drive and generator seals and the shared gasket.
Thanks!
Generator and Tach Drive Torques
- dstates
Re: Generator and Tach Drive Torques
The 100 Series Service Manual, 1962 and Prior has a torque-value chart, which is copied in the Mx LIbrary:
viewtopic.php?f=26&t=3571
- dstates
GAHorn wrote:The 100 Series Service Manual, 1962 and Prior has a torque-value chart, which is copied in the Mx LIbrary:
Thanks, George. I didn't see anything about generator mounting torques in the 100 Series Service Manual. I'm specifically looking for the torques on the engine accessory case studs. I will default to the general torques in the Continental M-O if I don't find a specific torque.
- n2582d
SB95-3B specifies 180-220 inch pounds for the generator mounting nuts. The tach drive housing is mounted with 1/4-28 nuts. Table B-5 in the Continental M-0 manual lists general torque specs for this size nuts as 90-100 inch pounds - significantly higher than the 50-70 inch pounds listed in the 100 series Service Manual.
- dstates
Thanks for the SB, Gary. I did end up using the general torque specs for both the 14/-28 tach drive nuts and the 5/16-24 generator nuts. As it works out the general torque for the 5/16 nuts is 180-220 in-lbs. and that matches with what the service bulletin has.n2582d wrote:SB95-3B specifies 180-220 inch pounds for the generator mounting nuts. The tach drive housing is mounted with 1/4-28 nuts. Table B-5 in the Continental M-0 manual lists general torque specs for this size nuts as 90-100 inch pounds - significantly higher than the 50-70 inch pounds listed in the 100 series Service Manual.
Thanks again!!
