Does anyone have a seat of lock bars for the Cessna 170 B. Cessna PN 0411629. The rear seat that came with my project is the later style that uses more of an arm with slots in it. The airframe is set up to just have the bent arm on the back seat. The bar is in the shape of like an S. If I could figure out how to add a picture to this post, I would post picture. In the IPC it is figure 31 I need item #20 the seat I have has item #21 in it.
Thank you again
Ben
0411629 seat back lock bar
- n2582d
Re: 0411629 seat back lock bar
Ben,
Hopefully someone who has converted to the Atlee Dodge or BAS/LakeVue Aeronautics folding seats will chime in and offer their seat back latch arm. If not, here is a photo of one on graph paper so you can fabricate your own. The rod diameter is 0.248”.
- bensmotorworks
Thank you so much. Turns out it is the same one that is used on the 140 also and I found a guy that might sell me his pins. We will see.
Thank you again
Thank you again
