Exploreit2 wrote:....What are the steps it would take to make my 54 B have a 10 Degree flap setting?
A really nice file and some time
Seriously this is one of the "no brainer" mods that if presented right to the local FAA should on a 337 should get approved but of course under change15/16 probably won't.
I'd talk to your FAA FSDO and tell them that first the "mod" is approved for this aircraft after certian serial numbers. Explain to them that you already can and DO fly with 10 degrees of flaps buy holding the flap handle in this postion
Not sure if the part numbers for the old and new rachets are the same. If they're not them tell them your going to modify the old part to the new part specs including the extra notch.
Not sure if the flight manual, the single sheet not the Owners Manual specifies the 10 degrees but if it does tell them you'll use the newer flight manual other wise there shouldn't need to be any flight manual change.
Basically I've found that the Feds have no clue how smaller GA aircraft work. They can't invision what you want to do so they can't figure out that it is a simple modification. You need to give them a arm and fuzzy feeling about the modification.
You need to be armed with enough information to answer all of their questions. Basically, baffle them with BS. Pictures and drawings, a 337 filled out with Instructions For Continued Airworthiness are must. A PowerPiont presentation might be over the top.
Tell them it would be safer (they love saftey) to have the notch to hold the flaps for you rather than you holding the flap handle.
If they don't feel good about the modification then the simple and safe answer for them is NO. They get paid either way.
Good Luck
