Authority for Aluminum Cleveland Wheels/Brakes
- gfeher
Per Parker Hannifin/Cleveland STC SA13GL, many years ago the wheels and brakes on my 170B were converted to p/n’s 40-97A (wheels) and 30-63A (brakes), both of which are magnesium. Does anyone know of another Parker Hannifin/Cleveland STC or other basis of authority for using or upgrading to Cleveland aluminum wheels and brakes on the 170B?
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
- cessnut
Re: Authority for Aluminum Cleveland Wheels/Brakes
Have you considered installing ABI aluminum wheels and double puck brakes? Pretty reasonable price(compared to Parker)and comes with STC.
- gfeher
Thanks cessnut. While I don't really need double pucks for what I do, It looks like the ABI 199-62 and 199-62A aluminum wheel and brake kits are the answer and the only current options. Both are for 1 1/2" axles and approved for all 170 models via STC SA02576AK. Kit 199-62 has 3-bolt wheels; kit 199-62A has 6-bolt wheels. There is another ABI kit, 199-71, approved for all 170 models by the same STC, that has 6-bolt wheels for 1 1/4" axles.
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
I have placed a call to Parker-Hannifin/Cleveland Technical and asked the question. I will post their answer when received.
Here is the response from Cleveland:
Hi George,
Thanks so much for your call into the Tech Line, yesterday regarding the 40-97A Cleveland wheels covered under STC SA13GL.
The 40-97A are magnesium and it is currently the only wheel approved for the Cessna 170s aircraft. There isn’t an aluminum version of the same wheel, so sorry.
I hope the above information is helpful. If I can be of any additional assistance please don’t’ hesitate to reach out to me.
Thanks,
_______________________________________________________________________________
Vern Rodgers | Products | Technical Manager|
Aircraft Wheel and Brake | Manufacturer of Cleveland Wheels & Brakes
1160 Center Rd, Avon, OH 44011| P: 440.937.1213 | vern.rodgers@kaman.com
Hi George,
Thanks,
- gfeher
Thanks for following up with that George.
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
