1956 170B PANEL
Juandi824
1956 170B PANEL
Post by Juandi824 »
Hello Everyone, does any one have a source to the CAD or Laser/jet printer file for a panel?
Re: 1956 170B PANEL
Firstly, you might supply your Serial Number rather than the Year-Model You Think your airplane is…. (airplanes are like farm tractors… the “year-model” often is determined by date-of-production …(or date of first sale for tractors)…which sets the “year-model” according to the FAA registry…. But the SERIAL NUMBER is what determines the actual model-design of the airframe. Example: My ‘53 B-model, according to FAA is a ‘52 model because it rolled off the assy-line Nov ‘52. This was only corrected by FAA after I informed them that it was NOT a 1971 model…as FAA had previously registered it when it was Re-Imported from it’s original destination / registered in El Salvador.)
And, You might want to be more-specific…. such as, the “floating panel”….or the Panel Overlay/Cover….. or the actual Part number of the item you seek:
Re: 1956 170B PANEL
First post I see. Welcome!
I'm assuming you're looking for CAD drawings of the shock mounted panel shown in figure 44 of the C-170B IPC. The part number for this panel is 0513004-11. It was used from 1953 and on for the C-170B and through 1958 on the C-172.
Juandi824
Re: 1956 170B PANEL
Post by Juandi824 »
yes, looking for the shock mounted panel. My serial number is 27008.
