IO-360 crankshaft?
Posted: Mon Jul 05, 2004 3:34 am
by zero.one.victor
A friend is buying an early O-300 powered 172, & was a bit concerned about engine parts availability,especially with regards to replacement crankshafts in case one was needed at overhaul time. The A&P owner of a local engine shop,which I believe is a CRS,told him that was no problem, that it was possible to just use the crank out of an IO-360.
Does anyone know if this is a factory-endorsed substitution?
Posted: Tue Jul 06, 2004 5:31 pm
by blueldr
I think that " engine " guy is really wrong. If new IO-360 cranks fit in O-300 type engines, used serviceable O-300 cranks wuold be a lot cheaper.
crankshafts
Posted: Sun Jul 11, 2004 1:17 am
by jatkins
I recently explored this crankshft question.
I was told , not having read it my self,
that the I0-360 crank will fit in the 0-300D ,
I recall mention of a service bulletin.
The only issue is the gear on the back mounts with different
size bolts , so a differant gear and bolts must be used .
Posted: Sun Jul 11, 2004 2:52 am
by blueldr
I still stand by my above statement.
