vert stab/fin fasteners
Wondering about bolts to fasten aft vert stab to empenage. In the IPC figure 13 shows attachment of "Fitting rear spar lower " with bolt NAS145-14s and NAS145-18. These are like big allen key bolts with hex socket in heads. Are these special and/or could regular AN bolts also be used? Thanks G
special bolts
I replaced those bolts on my plane while rebuilding it. If memory serves me correctly you couldn't get an external wrench on a standard bolt at that location. The fit is too tight. Those bolts aren't hard to order and are the only bolts I know of to fit there, as well as being the only "correct" bolts to use. Also I think they have special washers you have to use with them, that are chamfered in the opening, because the bolt is radiused at the shoulder. Good luck, Jon
- jlwild
The NAS145-14 & -18 bolts are special high shear and have been replaced
by MS 20005-6 & -11 bolts and high shear chamfered washers P/N MS 20002-5.
I ordered my replacement bolts/washers from Genuine Aircraft Hardware. Check them out on the web: http://www.gen-aircraft-hardware.com Also belive the minimum order for the washers was 25; so, make sure they are the high shear / chamfered ones.
If I remember correcly, I ordered the wrong ones the first time.
Jim Wildharber, Kennesaw, GA
I concur with jlwild. The MS20005 bolts are equivalent replacements.
I also concur with where to get them! (Genuine Aircraft Hardware).
Here are my notes when I ordered from them:
(2) MS20005-6 bolts @ $7.88 each = $15.76
(5) MS20005-9 bolts @ $8.58 each = $42.88 (sold in packages of 5 only)
(25) MS20002C5 counter-relieved washers @ $0.26 each = $6.50 (sold in packages of 25)
(25) MS20002-5 hardened washers @ $0.13 each = $3.18 (sold in packages of 25)
Total = $68.32 (+ shipping)
For what it's worth, buying the "original" NAS145 bolts from Cessna
would have cost $116.45 each (ouch....).
Bela P. Havasreti
'54 C-180
'54 C-180
Additionally,...using ordinary AN hardware in that location places unusual stress on the fitting because the chamfer/profile does not match. I've seen a few aircraft with ordinary AN bolts there. I wouldn't fly in them. IMHO. (And I wouldn't want to have to try finding replacement angles/attachment fittings when they eventually develop cracks.)
I am just reviewing notes from Bel and Jim . You note the dash numbers are different . two bolts with dash 6 but Jim I think you list dash 9and Bella, dash 11. Also You list 5 (five of the longer ones) I see spots for only 2 so where do the other 3 go?? Gonna order these up if you might be able to clarify these points. Thanks G
If I remember right, when I called them for the order,
they didn't have the exact dash-numbers on-hand (hence
the longer ones I reference).
The additional number of bolts stems from the fact that
(at least when I called them), you could only purchase
said bolts in lots/bags of five.
Maybe give them a call, and see if they have exactly what
you're looking for in the quantities you're after.
Bela P. Havasreti
'54 C-180
'54 C-180
