How to Do a Proper Groundloop
BloomerJohn
Post by BloomerJohn »
How To Groundloop Your Taildragger
Judging by how frequently it is performed, the Groundloop is indeed a
popular maneuver. The Groundloop is an extreme low-level figure that
is highly acrobatic in nature, which may be executed in many exciting
variations. It is customarily performed as the last figure in a
sequence, but I have seen the Groundloop attempted as a preliminary or warm-up maneuver.
It is rarely scored however, because it is most often performed out of
the Judges' line-of-sight. Also, the Groundloop is categorized as a
surprise maneuver, and therefore nobody is really prepared when it is executed.
In fact, the figure is not considered genuine unless Judges, spectators
and the pilot-in-command are all surprised! The many interesting and dynamic variations do not have a Degree of Difficulty or "K" attached, but rather are rated on the International HC* scale.
*Holy Cow
HISTORICAL PERSPECTIVE
The Groundloop is one of the earliest recorded aerobatic figures. It
was performed on virtually all of the taildraggers dating back to
Aviation's infancy. The maneuver really came into its own during the Golden Era of the Groundloop which was when the cross-wind landing was invented. Previous to this, circular landing fields were the norm and the pilot simply eye-balled the windsock, and landed into wind. However, it was soon discovered that a short, straight landing strip could be plowed out, and now there would be lots of room for hangars, clubhouse, and an expansive cocktail lounge.
Once everyone saw how much fun this new land-use concept generated, it was adopted internationally. The daily Groundloop displays were an instant hit, and helped cast the new idea in tarmac.
ANALYSIS
Most Groundloops are weathercocking related phenomena. This means that
at least one main wheel must be touching the earth, and a wind is
blowing. Traditionally, the maneuver is started in a cross-wind; during the landing roll-out the tail is allowed to be blown down-wind. At this point there are a variety of options that can be exercised depending on your inputs, and the maneuver can take off in almost any direction, and finish in a variety of attitudes. Groundloops that occur under calm conditions are more rare, and require vigorous control inputs, so you really have to work at it to get a decent one.
Groundloops can be generated anywhere from 5MPH to flying speed. When
executed at high speed, the figure covers more territory and generally
spawns the most interesting variations.
High-wing taildraggers probably Ground loop the best because the
upwind wing is more exposed to the breeze. The high-wing also enjoys a longer arm to really accelerate things once the maneuver starts. If the airplane is designed with the wheels forming a small triangle (short-coupled), and in the hands of the right pilot, this could be a Groundlooping champion.
ESSENTIAL BACKGROUND KNOWLEDGE
Avoid the study of the following subjects: a) Cross-wind Landings and
Take-offs. b) Ground-Handling in winds.
Avoid seeking instruction on these subjects, for it will greatly
reduce your chances of producing a truly World-Class Groundloop. Also, you might want to have a good line ready in case someone raises one of these subjects in conversation: "Cross-wind Landings, heck, wasn't that about lesson 5 on your Private License? I'm way beyond that.
PREPARATION
To be successful, we must prepare both pilot and aircraft.
PILOT
To perform good Groundloops, the best preparation is no preparation.
AIRCRAFT
The aircraft can be prepared in a variety of ways to ensure consistently good Groundloops. First of all, the main wheels should be shimmed to a toe-in condition. If the wheels are adjusted to track straight ahead or are shimmed slightly toe-out, the tracking will be too stable to assist your attempts at Groundlooping. Keep the tire pressures different from one another. If you know the direction of the cross-wind, reduce the pressure on the up-wind tire before going flying. And remember, it isn't necessary to change the tires until you can see the second ply of fabric showing; a blow-out can be the start of a dazzling Groundloop.
Avoid the hassle of taking off those trouble some wheel-pants by
putting a drop of Loc-tite on the screws. Now you have a good excuse not to inspect the brakes. So, when the brake fails on one side or the caliper pinches through a rusted disc, you will enjoy a splendid groundloop.
At the back end, you can start by loosening the fitting that holds the
tail-wheel spring to the fuselage. Just back the nuts off a few turns.
Also back off the nut that attaches the tail-wheel casting to the spring. Now, slack off the steering springs a couple of links so the chains sag. And while you're at it, cut off that lock wire that some conscientious Engineer installed in case the chains break. From time to time they break on landing and produce a thrilling, and rakish Cramer-like lurch. Fantastic!
These simple mods will produce a delightfully loose rear-end that feels like it's on ball-bearings.
The little tail-wheel is best left alone; over time it becomes worn
into an interesting cone-shape by the effects of slipstream, P-factor and gyroscopic effect. These left-turning forces create more wear on the starboard side of the tire, and soon you have a beautifully unstable little demon back there to really help you out.
Install the push-to-talk switch in a remote area of the cockpit. When
the tower talks to you on the roll-out, you can look down into the cockpit to locate the button, and when you look up, you may be treated to the wonderful green-and-blue kaleidoscope of rotation about the vertical axis.
TECHNIQUE (HOW-TO)
Once the pilot and aircraft are prepared, it's a little like shooting
fish in a barrel; there's really nothing to it. There are several things you can do to get the Groundloop going, but really the best thing to do is nothing.
Just let it happen. If you are landing or fast-taxiing in a cross-wind
and you want a Groundloop... you guessed it- do nothing.
Taxi with abandon. As a pilot, you are a free-spirited individual, and
this can be best displayed by a carefree jaunt down the taxiway. Just let go of the stick and use the hands-free time to organize your maps and sequence cards. If the tail-wheel comes off the ground, you're going a little fast.
Maybe you'll want to use the time to put on your seatbelt, polish the
inside of the canopy, re-tie your shoelaces or perhaps light up a smoke. Taildraggers have the right-of-way, so you won't have to stop
suddenly.
When cleared for take-off, start bringing the power up as you swing
out on to the runway Of course you'll want to shove the stick forward quickly to get that tail up (you can't get it up too soon). If the plane will fly at 50, hold it on until 65. This technique spreads out the landing gear and brushes off some rubber, but everybody does it and it looks cool. If you get rolling quickly, any cross-wind won't matter. Now rotate as you would a 767.
Haul straight back and blaze into the blue.
On the approach, keep it low and fast. If the airplane lands at 50,
cross the fence at 100. It's best not to have a planned touchdown point
because that can interfere with the free-spirited nature of the flying event. Start fanning the rudders through 500 feet, and keep it going until you've cleared the runway. The fanning technique is to let the airplane know who's boss. Get the plane down to the runway as soon as possible, and force it to land with plenty of forward stick. The fast-landing method is good for all weather conditions, especially quartering tail-winds. Once the plane is firmly on the ground, let go of the stick, but keep fanning the rudder to cool the tail-wheel assembly. Taxi in as you taxied out.
VARIATIONS
1. 45-Degree Overland Express.
This one is best done at about 40 MPH. The airplane is allowed to
weathercock slightly, the upwind wing and wheel are allowed to rise
about 3O degrees and the plane swings into wind. At 45 degrees off the runway heading, sharp downwind brake, full aft stick and aileron into wind are added to stop the Groundloop. The plane is now headed off overland.
This is useful for taking a short-cut to the washrooms after a long flight.
2. 90-Degree Quick Turn with Prop Curl.
Use the same technique as above, except at about 20 MPH. When you
stomp on the downwind brake, also shove the stick forward. Even though you are traveling slower, the gyroscopic effect of shoving the stick forward will give you that extra 45 degrees of rotation. The tail will rise briskly. As soon as the prop touches the runway, pull hard back on the stick and apply both brakes. This was how the original Q-Tip Propeller was invented. If you've done it just right, you'll probably have a much more efficient prop.
The Prop Curl can also be done straight ahead. Taxi at about 10 MPH
while tucking in your shirt or cleaning your sunglasses. Keep your hands off the stick and slam on the brakes. Voila! Also try this while maneuvering the tail-wheel over an obstacle. For a more dramatic Curl, hold the stick forward and add a burst of power.
3. Pitts Special Twin Arcs.
Start the Groundloop from the roll-out at about 25 MPH. Remove all
cross-wind inputs and allow the airplane to weathercock. Move the
stick forward to at least neutral to lighten the tail-wheel and reduce its directional control. The little biplane will rise up on the downwind wheeland begin a concise pirouette. The downwind wing-tip will hit the runway and begin scribing an arc of red butyrate, Dacron and plywood. Without hesitation slam in full upwind aileron, as if to attempt to lift the lower wing. The downwind aileron will shoot down and describe a beautiful red arc parallel to that made by the wing-tip. Pull the stick full back, push full downwind brake with full rudder and a burst of power to erect the plane.
These little red arcs are very artistic and will attract a good crowd
in the evening following the days flying.
4. 180-Degree Pirouette with back-track
This one is best attempted in a light high-wing with narrow bungee
landing gear, a Cub will do. The maneuver works best in a quartering
tail-wind. This figure looks difficult, but is really pretty simple. It works best if the pilot does not interfere.
Get the weather-cocking started in the usual manner. Move aileron
out-of-wind and push the stick forward to get weight off the tail. 20
MPH is fine. As the up-wind wing rises, the center of gravity swings as a pendulum toward the lower wing. About the time the down-going wing smacks the runway, the center of gravity will have swung to the outside of the downwind wheel.
Apply this brake hard. Now it's as if you had two upwind wheels
because the center of gravity has migrated outside via centrifugal force. So now it wouldn't matter which brake you applied, the effect would be to increase the rotation of the Groundloop.
The wing-tip smacks off the tarmac, the brake completed a full
180-degree turn, and fast-taxi back to the button.
5. Groundloop with Bunt.
This is certainly one of the more dramatic figures in the Groundloop
family. You'll want to be traveling a little faster to get this one. Say 35 MPH. The figure should start slowly then get faster and tighter as rotation sets in.
A dry runway is necessary, and a quartering tail-wind from the left is
best. Once rotation starts, shove in full down-wind stick and full forward elevator. This will really tighten up the rotation. Now add full brakes and full power. The tail will shoot upwards and the airplane will do a kind of shoulder roll right on to its back. This is really low-level inverted, and you should ensure that your belts are very tight. This figure should be reserved for the last flight of the day.
CONCLUSION
The Groundloop has been around for almost a century and I'm sure it
will be with us forever. And to keep it alive, all we have to do is be a little complacent, a little cock-sure and in a little hurry. Most important, one needs a thorough misunderstanding of weathercocking, cross-wind take-offs, landings and ground-handling. Sounds pretty easy to me.
enjoy your spin-around
Ha! (And don't forget to tell 170'ers not to bother disabling their parking brakes.)
Thanks, John. Send it to Velvet. :lol:
I recently saw this essay posted on another website forum. Excellent! My hat is off to the author, whoever he might be.
rudymantel
Post by rudymantel »
My guess- the author is a Pitts pilot. Excellent !
Rudy
C-170B N4490B
Plantation Florida
(Based at North Perry Airport,
KHWO, Miramar FL)
johneeb
Post by johneeb »
Rudy,
This bring to mind the string reguarding your tail wheel spring spacer. Is your tailwheel behaving better with the steel spring spacer installed. :?:
rudymantel
Johneb, yes, my tailwheel is fine with the steel spacer- even on the roughest road !
Rudy
C-170B N4490B
Plantation Florida
KHWO, Miramar FL)
