Thanks everyone for the information you sent me regarding my "gear legs" question I posted earlier this year. It's appreciated.
After a lengthy rebuild, my 1954 170B is reassembled and painted and I can finally see light at the end of the tunnel.
I am currently working on the rigging of all control services and have been referring to both the Cessna 100 series manual and my owners manual for information. The problem is that my plane preceeds a lot of the information for 170s in the 100 series manual so, for some things, I've been bouncing between information for the 172 and 180.
I would like to confirm "travel" details, cable tensions, etc. Does anyone have a source, other than what is in the two books that I have, to check these details?
Pat Mitchell.
rigging of control services
The Owner's Manual has those specifications for your airplane. I'll email the rigging instructions to you when I return home from this trip (if I can remember. Remind me in a couple of days. Memory is a fading thing.... ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
This subject reminds me. I found a neat and cheap little gadget for checking the horizontal control deflections at Home Depot. It is an angle measure that you can just set atop the surface and measure the deflection. It cost about ten bucks and is handy around the hangar. It will not work on the vertical surfaces though (i.e. the rudder).
David
David
Re: rigging of control services
Pat Mitchell.[/quote]
The travels are on the type certificate data sheet. Which can be accessed on the FAA web sight at http://www.faa.gov click on aircraft. Then select type certificate data sheets. Select manufacturer and then select your model of aircraft.
