Flang Pushrod Housing Cracks
Robert Eilers
Post by Robert Eilers »
Has anyone experienced cracks in the Pushrod Hosuing Flang (Part #530163) - just above the lower bolt hole? I recently had a pushrod hosuing modification kit installed - to eliminate oil leaks associated with the pushrods. However, after the installation leaks began to appear and were traced to what is described as cracks in the puhsrod housing flang. My mechanic is in the process of trying to locate replacement parts for the cracked flangs. Curious is this is a common or extraordinary occurence.
N170BP
Post by N170BP »
Did you install the Real Gaskets push-rod retrofit kit? (O-470
style, spring-loaded pushrod tube arrangement). If so, the
instructions warns about over-torquing the nuts that hold
the pushrod base casting (what I think you're calling the flanges?).
I don't have the instruction sheet handy, but the torque specified
ain't much.... Since they are "plain" nuts, I suppose they are suspect
to them backing off and losing torque (which is probably what causes
folks to "give them a good twist" in an effort to keep them from leaking).
Don't say I said so, but a guy could install steel locknuts instead of the
plain nuts in an effort to keep them from losing the (admittedly) light
torque they're supposed to get in the 1st place....
Bela P. Havasreti
'54 C-180
Robert Eilers
Yes, I installed the Real Gasket Push Rod Modification Kit. We were all aware of the torque limitation on the nuts. I had the same installation done on my Champ with no problems and no cracks. Caused me to wonder if cracks in the push rod housing was a common problem.
